9 years agolpm_add_sub - signed
Sorry for maybe a silly question but my brain stopped working.
I add 2 9-bits signed numbers. The result is also 9-bits. what do i do with the overflow bit? To illustrate: logic signed [8:0] data_a; logic signed [8:0] data_b; logic signed [8:0] result_temp; logic signed [9:0] result ; logic overflow; adder_module U1 (.clock(clk), .dataa(data_a), .datab(data_b), .overflow(overflow), .result(result_temp)); assign result = overflow + result_temp; or I have to do this: assign result = {overflow, result_temp}; Interested especially when deal with negative numbers. And if my result signal is much larger than [8:0] result_temp. I've tried simulate in Modelsim and even if my "result_temp" is negative I always get positive "result".No RepliesBe the first to reply
