17 years agoThe transition from 2s complement to unsigned is performed by inverting the MSB (this is the same as adding half dinamic range), and everything works if the original 2s complement signal is not overflowing or underflowing.
So before your multiplication you have to perform the conversion and your multiplication will work in unsigned mode.
