17 years ago --- Quote Start --- Yes, filter is recursive and the 7th order. b0y(n)=a0x(n)+a1x(n-1)+...+a7x(n-7)+b1y(n-1)+b2y(n-2)+...+b7y(n-7) --- Quote End --- The filter is recursive has any IIR filter, but the formula is a standard form of z transfer function, I wouldn't regard it as recursive. Coefficient resolution utilisation is ineffective in the standard form, cause a large range has to be covered. I found 18 bit resolution (13.5) is required for an acceptable frequency response in the present case, 16 Bit has an considerable magnitude error. In contrast, a cascaded form using first and second order building blocks achieves similar results with only 10 Bit (9.1) coefficient resolution.
