14 years agoLow Frequency PLL Multiplier
For a video genlocking application I need to multiply an incoming ~15KHZ clock by ~2000 to produce ~30MHZ. The input frequency is too low for the PLLs in my Cyclone III and I've been straining my br...
14 years agoDepends on your requirements for the 30 MHz clock. If you can accept larger jitter for it, a regular all-digital PLL can be solution. Alternatively, a quasi-continuous digital PLL (jitter < 0.5 ns) can be build using the PLL dynamic phase shift feature, but the lock range will be limited.
