14 years agoLoss of FPGA configuration
To minimize power consumption, I have the Oscillator input of the main part of my Stratix III design gated (glitchfree keeping low, if gated). Connected to this clock (50 MHz) are two synchron...
14 years ago --- Quote Start --- I wonder, if the current transient may be normal operation and the voltage drop primarly a board hardware problem. --- Quote End --- Actually, this was it. A little embarassing for me, but I stopped the power supply synchronisation as well, when going to sleep mode (and so having a weakness in supply at the begin of the sleep mode). Using a clock that doesn't stop makes the sleep mode work perfectly, even when just gatinng the input clock. Additionally putting the DDR I/F into reset state prior to the ghating is even slighly better from a consumption point of view. Sorry for bothering you about this, the hints were great help just the same!
