14 years agoLoss of FPGA configuration
To minimize power consumption, I have the Oscillator input of the main part of my Stratix III design gated (glitchfree keeping low, if gated). Connected to this clock (50 MHz) are two synchron...
14 years ago --- Quote Start --- To get clarity about the effect, I would either measure the respective supply rail dynamic current or check the power supply transient response with a test load. --- Quote End --- I'm going to do that in near future. In meantime: Which dynamic current peaks would you expect putting a PLL into reset mode without gating it's input clock? Actually, the same 2.5V supply I use for VCCPD powers VCC_CLKIN3C/4C/7C/8C, too. According to spec, these supplies may draw up to 250mA each. May this be the hot spot in question?
