18 years agoLooping error
this is typical counter description, but how there's this error when i try to compile it in quartus --- Quote Start --- Error (10500): VHDL syntax error at count31.vhd(31) near text "i...
18 years agoHere's the scenario, typical camera have vsync,href,pclk and 8-bits data.
vsync represents new frame href represents new line pclk represents new pixel http://img85.imageshack.us/img85/3275/outputsignalue4.jpg I would like to capture the first 50x50 pixels of the frame and another frame after the 60th frame. All I need is two frames. I'm getting this error --- Quote Start --- Error (10519): VHDL Type or Variable Declaration error at camera.vhd(44): bounds of type or variable range must have same type --- Quote End --- --- Quote Start --- Error (10515): VHDL type mismatch error at camera.vhd(44): integer type does not match string literal --- Quote End --- Here my code: --- Quote Start --- LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.numeric_std.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; ENTITY camera IS PORT ( start : IN STD_LOGIC; pixel : IN STD_LOGIC_VECTOR(7 DOWNTO 0); clk : IN STD_LOGIC; vsync : IN STD_LOGIC; href : IN STD_LOGIC; pclk : IN STD_LOGIC; pixel_out : OUT STD_LOGIC_VECTOR(7 DOWNTO 0); reference : OUT STD_LOGIC ); END camera; ARCHITECTURE behave OF camera IS SIGNAL frame_count : STD_LOGIC_VECTOR(6 DOWNTO 0); SIGNAL line_count : STD_LOGIC_VECTOR(6 DOWNTO 0); SIGNAL pixel_count : STD_LOGIC_VECTOR(6 DOWNTO 0); BEGIN PROCESS (vsync, href, pclk) BEGIN IF start='1' THEN--------------------------------------------STARTS THE CAPTURING SEQUENCE frame_count <= (OTHERS => '0'); line_count <= (OTHERS => '0'); pixel_count <= (OTHERS => '0'); IF(vsync'EVENT AND vsync = '1' ) THEN FOR frame_count IN "0000000" TO "111100" LOOP frame_count <= frame_count + "0000001"; -------------COUNTS FRAME UNTIL 60 IF(href'EVENT AND href = '1' ) THEN FOR line_count IN "0000000" TO "110010" LOOP line_count <= line_count + "0000001";---------COUNTS LINE UNTIL 50 IF(pclk'EVENT AND pclk = '1' ) THEN FOR pixel_count IN "0000000" TO "110010" LOOP pixel_count <= pixel_count + "0000001"; --COUNTS PIXEL UNTIL 50 pixel_out<=pixel;-----------------------------OUTPUTS THE PIXEL DATA reference<='1';------------------------------FOR SAVING THE DATA INTO RAM PURPOSES END LOOP; END IF; END LOOP; END IF; END LOOP; END IF; ELSE null; END IF; END PROCESS; END behave; --- Quote End ---
