18 years agoLooping error
this is typical counter description, but how there's this error when i try to compile it in quartus --- Quote Start --- Error (10500): VHDL syntax error at count31.vhd(31) near text "i...
18 years agoexpecting ";" means in most cases just this: a ";" is missing (usually in the previous line).
After correcting the simple syntax error, the compiler sees that the code isn't synthesizable at all, cause it has an endless loop. I also don't understand what is intended here.
