Mikexx
3 years agoLocked signal stays low for Cyclone V PLL
I'm using a simple PLL using a 50MHz clock source to produce a 300MHz clock using a PLL IP in simple "Integer-N PLL" mode.
The 300MHz clock is fine and if I divide by 6 and count I can compare it ...
Ash_R_Altera
3 years agoHi,
As there is no further response to the case, I am setting the case to closure. However, it will still be open for the community members to comment. Please feel free to open a new case if you need support.
- Mikexx3 years ago
Sorry it's taken so long to reply.
The Locked signal would stay high if I set the "PLL Bandwidth Preset" to "High".
I also added some extra decoupling on the 2.5V rail.
I also entered the clock period into the Timing Analyser as I wasn't sure if the dips in the lock signal were due to SignalTap sampling.
It's now reliably high.
