Mikexx
3 years agoLocked signal stays low for Cyclone V PLL
I'm using a simple PLL using a 50MHz clock source to produce a 300MHz clock using a PLL IP in simple "Integer-N PLL" mode.
The 300MHz clock is fine and if I divide by 6 and count I can compare it ...
Ash_R_Altera
3 years agoHi,
You are right. "Locked" signal should stay high.
But, in spite of locked = '0' are you seeing a stable clock output? This sounds strange.
Can you check if you are probing the right PLLs locked output in signal tap?
- Mikexx3 years ago
It is my presumption that locked should go, and stay high.
The source is a 50MHz clock module and this has already been used to create a fractional PLL working at 148.5MHz for an HDMI clock and the evidence shows this is stable. This was another design to prove the HDMI interface.
I am using signal tap and looking directly at the locked signal. It stays low.
Many thanks for your reply.
