Mikexx
3 years agoLocked signal stays low for Cyclone V PLL
I'm using a simple PLL using a 50MHz clock source to produce a 300MHz clock using a PLL IP in simple "Integer-N PLL" mode.
The 300MHz clock is fine and if I divide by 6 and count I can compare it ...
FvM
3 years agoHello,
can you show all parameters that are defining the PLL? What's the input clock source?
Regars,
Frank
Regars,
Frank
