18 years agoloading .bmp files in Simulink...
Hi guys, I'm testing the reference design in Simulink 7.2 Avalon Edge detector. This example works fine, but the image load and image viewer were implemented using .m matlab script using ...
18 years agoHello,
The scripts are invoked using simulink callbacks. Once the .mdl file loaded, right-click on the main window and select Model Properties. From there check the content of the Callbacks tab. The procedure might vary a bit depending on the matlab version you are using. http://www.mathworks.com/access/helpdesk/help/toolbox/simulink/index.html?/access/helpdesk/help/toolbox/simulink/ug/f4-146273.html#f4-140344 v
