8 years agoLM_LICENSE_FILE or MGLS_LICENSE_FILE for RTL simulation
Hi, Im running quartus lite 17.1.0 on ubuntu 17.04. When I try to run RTL simulation I get an error output about LM_LICENSE_FILE or MGLS_LICENSE_FILE. The path to /modelsim_ase/linuxaloem is se...
8 years agoWhen you install the tools under Linux, you need to specify the License file location . This is done by specifying the following variables:
LM_LICENSE_FILE --> path to license file for all tools which use FLEXLM licensing MGLS_LICENSE_FILE --> specific license variable for Mentor Graphics tools You will need to edit the .bashrc or .cshrc file in your login and add the following variables there export LM_LICENSE_FILE = <path to your license.dat file> export MGLS_LICENSE_FILE = <path to your license.dat file> export PATH = $PATH:<path to modelsim executable>:<path to quartus tool executable> Save and close the .bashrc/.cshrc file. Start a new terminal and you can invoke the tools .
