llegal connection on I/O input buffer primitive [1704]
Hi Avichay,
Can you please elaborate what you are trying to achieve when you say "net that drives out to destinations other than the specified I/O"?
A pad pin of the FPGA is hardwired to an input buffer. It cannot drive the internal FPGA core logic directly. So make sure that you are not inserting any logic in between the pad and the buffer.
To enable OCT for differential pins, you can enable it in the Pin planner or in the .qsf file.
Regards.
- Avichay5 years ago
Hi Ash_R
Thanks for answering.
pls see attached screen shot of the issue.
the qsys of the example design ed_synth works ok but when putting it on a simple top i get the below error.
The error i get is :
Error(17044): Illegal connection on I/O input buffer primitive u0|pci_ddr_emif_0|pci_ddr_emif_0|arch|arch_inst|bufs_inst|gen_mem_dqs.inst[4].b|cal_oct.ibuf. Source I/O pin .
