15 years ago'Leaving target processor paused'
When I used the nios-ide (in Ubuntu 10.10), I met a error message below. /opt/altera/10.1sp1/nios2eds/bin/nios2-download: 24: function: not found cd: 55: Illegal option -- eval: 1: search_f...
15 years ago --- Quote Start --- When i found this problems with my own designs would be, all the time, that i have surpased the fmax acceptable for the system/FPGA i was running on Maybe with a time constraining you will fix this. What i have found to work is (obviously) to low the clock speed to slower values. (For example, NIOS II running over 110 MHz in a 7 speed grade Cyclone II would fail to verify; after making the clock 100MHz, it would run find) --- Quote End --- Thanks for your reply! Your message is very helpful. But I think my problem is about the nios2eds for Linux version. Because I downloaded the nios2 sys using Windows version, and it ran well.But I downloaded the same project using the Linux version, it couldn't run well. Maybe there were some error when I installed the Linux version, and some .so file couldn't be found. And I use the command 'sudo ln -sf ' to link the .so file.But I thought there were some other errors. Maybe the nois2eds for Linux version does not work well on Ubuntu, and maybe it will work well on the RedHat. I had change to the Windows xp. After accomplishing my project which my teacher assigned to me, I will try to solve it. And thanks to you again.You message is really helpful. If you installed the nios2eds on Ubuntu, please share your installation experience to me!
