14 years ago
Leaving target processor paused
I tried to run hello_world project in Nios II, and I got this message. Can anyone help me solve this?
Using cable "USB-Blaster ", device 1, instance 0x00
Processor is already paused
Reading System ID at address 0x000000B8: verified
Initializing CPU cache (if present)
OK
Downloading 00200060 ( 0%)
Downloaded 4KB in 0.0s
Verifying 00200060 ( 0%)
Verified OK
  • AAlas3's avatar
    AAlas3
    Check if JTAG UART core is included in Qsys design, if everything is in there try to rebuild the system from scratch (delete the whole project file and build it again), I faced the same problem and tried to rebuild the system again from scratch and it worked.
    Check the reset signal
    What command are you using? I usually go with nios2-download -g -r file.elf
    Check if Nios reset and exception vectors are placed in a valid memory area.
    Also try Debug instead of Run
