18 years agoLCD without SOPC builder and NOIS II
is it possible to use LCD by write a program in verilog without using SOPC builder and NOIS II?? if so, can you tell what steps should i go through? i have DE2 board!
18 years agoAttached a Verilog sample LCD driver.
It initializes then continuously updates a 16x2 LCD from a bank of wires. The wires are ASCII chars, "Hello there 32 chars ..." etc. The timing can be a little bit finicky. I had to add some proper timing constraints to the output signals to get it working on a Cyclone III DSP board.
