14 years agoJTAG/IO Clamping and Hot-swapping
I am putting Cyclone IV GX on a new board that will be configured using PS. Since all the VCCIOs are 3.3V, I am planning on clamping the the JTAG and PS config signals using a pair of schottkys betw...
14 years ago --- Quote Start --- Any clever ideas out there to deal with this? --- Quote End --- My personal preference is to protect JTAG and external I/O using Fairchild TinyLogic or TI LittleLogic parts. http://www.fairchildsemi.com/products/logic/tinylogic/ You can power them from 3.0V, so you do not need the clamp diodes, and their inputs are tolerant to 7V when power is off, eg., http://www.fairchildsemi.com/ds/nc/nc7wz16.pdf (http://www.fairchildsemi.com/products/logic/tinylogic/) If you are designing your hot-swap system to correctly sequence power supplies, then these buffers can be part of that sequencing. If you are plugging into a powered backplane, then you can use hot-swap buffers with a 1V bias voltage on their output. See the following schematic for examples: http://www.ovro.caltech.edu/~dwh/carma_board/ (http://www.ovro.caltech.edu/%7edwh/carma_board/) http://www.ovro.caltech.edu/~dwh/carma_board/gda06rb004_carma_v0.87_dec03.pdf (http://www.ovro.caltech.edu/%7edwh/carma_board/gda06rb004_carma_v0.87_dec03.pdf) Cheers, Dave
