15 years agoJTAG to Avalon master bridge usage
Hi, The main issue i want to ask is whether the jtag to avalon master bridge IP core can be used to communicate data between PC and the FPGA, even if the board does not have JTAG connector. My ...
15 years agoHello Everyone,
I need some help with using System Console. I have created a Qsys system that consists of a JTAG to Avalon Master Bridge (Master) and an Avalon Memory Mapped Slave. The slave is created using a .vhd file which has the following ports: csi_clockreset_clk : in std_logic; csi_clockreset_reset_n : in std_logic; avs_qsys_read : in std_logic; avs_qsys_readdata : out std_logic_vector(15 downto 0); avs_qsys_write : in std_logic; avs_qsys_writedata : in std_logic_vector(15 downto 0); avs_qsys_address : in std_logic_vector(15 downto 0); coe_writedata_ext : out std_logic_vector(15 downto 0); coe_write_ext : out std_logic; coe_read_ext : out std_logic; coe_address_ext : out std_logic_vector(15 downto 0); coe_reset_ext : out std_logic; coe_clk_ext : out std_logic; coe_readdata_ext : in std_logic_vector(15 downto 0) And, I perform the following assignments: coe_writedata_ext <= avs_qsys_writedata; coe_write_ext <= avs_qsys_write; coe_read_ext <= avs_qsys_read; coe_address_ext <= avs_qsys_address; coe_reset_ext <= csi_clockreset_reset_n; coe_clk_ext <= csi_clockreset_clk; avs_qsys_readdata <= coe_readdata_ext; The address map for the Qsys is 0x00000000 to 0x0001FFFF. Now, I used this Qsys system and an external RAM (megawizard function) to perform reads and writes to the memory. I am using System Console, in Qsys, to run a TCL script to perform reads and writes using the following commands: master_write_16 and master_read_16 I have also added a signaltap file to the project to monitor changes in the signal values. Now, in the System Console window in order to read and write to address 0x0000, I used the following commands: 1. master_write_16 $jtag_master 0x0000 0x1 2. master_read_16 $jtag_master 0x0000 1 After each command I check the values shown by signaltap. For all the address entries, the data written and read for the memory is consistent. But, the address shown by signal tap (coe_address_ext) is not the same as the address I accessed using the TCL command. I do not understand as to why is the address value captured by signaltap different then what I am entering using tcl command. Is there some kind of address mapping? I will appreciate if someone can help me with the issue. Thanks.
