15 years agojtag pin voltage levels
I am trying to connect cyclone 4 device with a usb blaster programmer Will there be a problem with the attached voltage levels and resistors?
15 years agoPin 4 of the JTAG connector should connect to the VCCIO of the IO bank containing the JTAG pins, either if its 2.5, 3 or 3.3V. The pull-up resistor would use the same voltage.
