10 years ago
jtag issues De0-nano-soc
I've tried this on three machines with no luck soooo...
Current Platform Quartus 15.1 / CentOS release 6.7
I've downgraded this box from usb xhci which had issues
Now - as root
# jtagd --foreground --debug
JTAG daemon started
Using config file /etc/jtagd/jtagd.conf
Remote JTAG permitted when password set
USB-Blaster firmware download ok (23ms)
USB-Blasters reconfigured, waiting for them to come back
USB-Blaster "DE-SoC" firmware version 1.35
USB-Blaster endpoints out=04(512), in=88(512); urb size=4096
USB-Blaster firmware for 09FB/6010 is version 1.35
USB-Blaster added "DE-SoC [2-1]"
Device /dev/bus/usb/002/036 remove
Device /dev/bus/usb/002/037 add
and as soon as i run
#jtagconfig
1) DE-SoC [2-1]
Unable to lock chain - Hardware not attached
this is nonsense as above it found the firmware ver ....
& the debug stream says :
USB-Blaster port (/dev/bus/usb/002/037) can't reset interface (71)
permissions are wide open
crwxrwxrwx. 1 root root 189, 162 Jul 19 20:08 /dev/bus/usb/002/037
I have 'occasionally ' got jtagconfig to recognize the chips on the board but as soon as i try writing / query from SignalTap it complains the same refrain:
"Unable to lock chain - Hardware not attached"
works fine with a DE0-nano ...
so any clues ? --
I've pretty much debuged with a external logic analyser( and printf) till now
... but that is getting difficult for many aspects ....
