JTAG Connection
- 5 years ago
Hi Yuto,
For cyclone 10 LP, you may refer to pin connection guideline at link below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/cyclone-10/pcg-01021.pdf
It would be better if you could follow the guidelines as stated for JTAG pin. The potential problem might be happening is on programming part.
Thank You.
Hi Yuto,
Thank You.
Hi.
Thank you for your answer.
I now understand that there could be a problem with the program.
I will fix the circuit.
Best Regards.
