15 years agoJTAG can not find device MAXII
Hi everybody, we are using a MAXII EPM570GT100C5N on Quartus Quartus 9.1 Build 350 03/2010 SJ Web Edition in Windows XP. We have Altera USB-Blasters for programming and we get the following er...
15 years agoI suggest getting this to work using jtagconfig on the command line rather than using the programmer window.
Error 82 indicates a failure to communicate with jtagserver. Check that there is a process called jtagserver running, and check that it has opened port 1309. `netstat -an` should show jtagserver listening on this port and should show a connection between the quartus process and the jtagserver process on this port
