15 years agoJTAG and/or IO pin usage
Hello all, I'm new to CPLDs but I'm very keen on getting a little project up and running soon. The basic question is: is it possible to program a EPM3064 through the JTAG pins, then use th...
15 years ago --- Quote Start --- I'll just treat the JTAG port as if it's always a JTAG port then, and double-up the JTAG connections to spare IO (which I have heaps of) and be done with it - easy! --- Quote End --- ??? --- Quote Start --- If JTAG can't be reenabled easily I won't bother disabling it. --- Quote End --- Unselect the "Enable JTAG BST support" option in "Device and Pin Options/General Tab". Then the four JTAG pins are available for assignment as general I/O. I agree, that the description of this feature in the device hardware manual isn't particularly clear. I didn't try it yet, but it's obvious to me, that the JTAG functionality can't be re-enabled with standard low voltage levels, otherwise the usability of the respective I/O pins would be restricted.
