15 years agoJTAG and/or IO pin usage
Hello all, I'm new to CPLDs but I'm very keen on getting a little project up and running soon. The basic question is: is it possible to program a EPM3064 through the JTAG pins, then use th...
15 years ago --- Quote Start --- 1) I need the 5V-tolerant inputs 2) because it's still pretty cheap (I was originally looking at the epm3032 which is very cheap, but alas too small) --- Quote End --- Fair enough. I'd place-and-route your CPLD design before making any final decision (since the part is a logic cell light-weight). If you need more logic, then you can use bus-switches to get 5V tolerance. The schematic I referenced has a 5V tolerant, hot-swappable, compactPCI interface. Cheers, Dave
