15 years agoJTAG and/or IO pin usage
Hello all, I'm new to CPLDs but I'm very keen on getting a little project up and running soon. The basic question is: is it possible to program a EPM3064 through the JTAG pins, then use th...
15 years ago --- Quote Start --- http://www.altera.com/literature/dp/max3k/epm3064a.pdf The JTAG pins are dedicated pins that cannot be used as I/O afterwards. --- Quote End --- Oops, my bad, I didn't read note (1) :) It looks like you can use them as I/O. But perhaps as FvM suggests, its only if you disable JTAG. In that case, you can use the scheme I mentioned. Cheers, Dave
