15 years agoJTAG and/or IO pin usage
Hello all, I'm new to CPLDs but I'm very keen on getting a little project up and running soon. The basic question is: is it possible to program a EPM3064 through the JTAG pins, then use th...
15 years agoHi wombat & FvM,
Thanks for the replies. If JTAG can't be reenabled easily I won't bother disabling it. Ok, I'll try with GCLRn & TCK tied together; so whenever I want to reset my CPLD I'll pull TMS high and clock TCK until the TAP's in test-logic-reset and the all my registers have been cleared. The I presumably have TMS/TDI/TDO available for inputs? I might connect TMS/TDI/TDO to some other IO points initially in case they're not available. Thanks again, Regards, Doug.
