12 years ago --- Quote Start --- Hi would the USB-Blaster compatible with the old Max2Plus version 10.1 or i need to purchase a newer version of max II plus. I can download the driver from the website but the version of maxII plus i have does not have a drop down menu in hardware setup for USB-Blaster. The only usb device option i have is APU. please suggest thansk --- Quote End --- You should not need to use MAX+Plus II at all :) Quartus II 9.0sp2 can be used to work with older series devices, eg., FLEX10K, ACEX, etc. To use the USB-Blaster to program any devices, just install the Quartus II Programmer. Cheers, Dave
