13 years agoJTAG- USB byteblaster programming cable
Dear sir, We plan to connect all the devices in JTAG chain (please find the document attached) in a board. When programming cyclone-IV FPGA using JTAG interface using USB byteblaster, do we ...
13 years ago --- Quote Start --- tell me if this makes sense i was thinking of using the same byteblasterMV cable using my laptop and buy usb to parallel port cable as byteblaster mv has a parallel port connector on one end. hopefully it would work. --- Quote End --- Its highly unlikely that you will get it to work. I haven't heard anything good about parallel port programming with USB-to-parallel ports, so don't hold much hope for Altera's interface supporting it. If it did work, it would be really really slow, since the ByteBlaster cables are digital I/O, eg., set TCK = 0, set TMS = 1, TCK = 1, then 0, etc. All those operations will occur in USB transactions every 10ms (or 1ms I forget) ... give up now! For $50, just buy a USB-Blaster. Cheers, Dave
