18 years agoJrunner + Serial Flash Loader (SFL) + EPCS4 [How to programm EPCS without Quartus II]
Hello, I'd like to adapt Jrunner to work with Serial Flash Loader. I've integrated SFL megafunction into my design and it works great. When I click auto detect in quartus II programmer it detects ...
15 years ago --- Quote Start --- ALTASMI is used to access EPCS through FPGA. I've added ALTASMI module in my FPGA configuration to erase EPCS device and send data to it. --- Quote End --- thanks for your reply, e ~, do we not use the sfl module that our discussed before ? i try to add the ALTASMI_PARALLEL module in my configure ,then how to connect/configure the pins on the modules? and if i have configure the fpga with this configure file,how to send data to the fpga to read/write the epcs via jtag? have some protocol such as AS mode? thank you once again..
