18 years agoJrunner + Serial Flash Loader (SFL) + EPCS4 [How to programm EPCS without Quartus II]
Hello, I'd like to adapt Jrunner to work with Serial Flash Loader. I've integrated SFL megafunction into my design and it works great. When I click auto detect in quartus II programmer it detects ...
15 years ago --- Quote Start --- oposdasdsWell, I used ALTASMI_PARALLEL to get access to my epcs16. Now I have some strange behaviour and try to describe it. LPC - my microcontroller (lpc2138). FPGA - Cyclone II, EP2C8T144 EPCS - EPCS16 1. LPC configures FPGA (via JTAG, with Jrunner port and array of *.rbf data) 2. LPC erases EPCS (uses newly configured FPGA with ALTASMI) 3. LPC writes the same array of *.rbf data to EPCS as to FPGA. 4. LPC checks data from EPCS byte-by-byte. All seems to be ok, but after I power off the device and tur it on again, EPCS do not configures FPGA. Can anyone tell me what's the issue? --- Quote End --- hi EnotAruz, the same to u ,i have done the first step that have configured the FPGA via the Jrunner;and then ,how to erase the epcs device and send the data to write epcs or read data. i see that u use the ,wahts that ? a IP? is it contained in the .rbf file at our first step generate? and whats the usage of ALTASMI? Look forward to your reply.thx alot:):)
