10 years agoIssues with Max10 push button
Hi, I'm using MAX10 FPGA development kit with 10M50D F484 package FPGA. But I'm having some problems regarding using the push buttons present in the board. As per the data sheet the push button...
10 years agoThey look terrible. However, I wouldn't rely on the built-in self test. Use an oscilloscope - assuming you've access to one - and look at all the rails I mentioned; they all go to the FPGA (although aren't all required to get the FPGA up). If you've no scope then at least check the rails with a multimeter.
Does the embedded USB-Blaster work? Cheers, Alex
