10 years agoIssues with Max10 push button
Hi, I'm using MAX10 FPGA development kit with 10M50D F484 package FPGA. But I'm having some problems regarding using the push buttons present in the board. As per the data sheet the push button...
10 years agoThat doesn't sound particularly good. Check the power rails on the board. Assuming it's the board I think you're referring to, check for each of the 1.2V, 1.5V, 1.8V, 2.5V 3.3V & 5V rails generated from the Enpirion devices. Check they're all good. Refer to the schematic for the board if necessary.
Cheers, Alex
