13 years agoIssue when deleting SOPC components in Terasic's demo projects
Hello all,
I am using Quartus II V.10.1 with a DE2 board. I'm trying to modify DE2_SD_Card_Audio from Terasic's V.1.6 demo CD. Specifically, there is an error with the USB component (ISP1362) that is preventing system generation in SOPC builder: error: isp1362:avalon_slave_1_irq: "associated addressable interface"(assocaitedaddressablepoint) out of range. There is discussion here...(can't post link, sorry): alteraforum.com/forum/showthread.php?t=20570 ...on what to do. However, I don't plan on using the USB port at all (or the VGA and Ethernet - DM9000A), so I simply deleted the components from the SOPC builder, generated, updated my top-level file, and compiled in Quartus II. Everything went well until I tried to create a new Nios II C/C++ Application - "Hello World" project in the Nios II IDE (V10.1). I can build/compile fine, but when I try to run my project as Nios II Hardware, all I get is: nios2-terminal: connected to hardware target using jtag uart on cablenios2-terminal: "usb-blaster [usb 2-1.1.6]", device 1, instance 0
nios2-terminal: (use the ide stop button or ctrl-c to terminate) ...on my Console screen. It doesn't appear to go past that point to print "Hello World." I can't figure out what is going wrong at this point, has anyone had a similar issue or know of a solution? Thanks in advance! ~Sarengo
