15 years agoIs this possible?
Hi everyone, I have a DDC logic and also runs in modelsim. Now, I want to plug into SGDMA to run. My DDC comes with multi clocks, inputs and also multi outputs. My question is that possible to...
15 years agoThanks Daixiwen,
Ok. Here is I'm trying to do. I try to use mux/demux in between sgdma 1:3 and 3:1 to see the result from output. sgdma (mm_to_st) -> channel_adpater_A -> demultiplexer -> A (my_module) -> multiplexer ->channel_adapter_B -> sgdma (st_to_mm) When I run Nios IDE, I could see the result just 1 input (first one) and 1 output. If I assign to the second input, I get 0 result coming out. Do I need to modify demux module to make it works. Sean
