15 years agoIs this possible?
Hi everyone, I have a DDC logic and also runs in modelsim. Now, I want to plug into SGDMA to run. My DDC comes with multi clocks, inputs and also multi outputs. My question is that possible to...
15 years agoThose connections should work. However I think the SGDMA doesn't support channels, so as a result all your packets from the SGDMA will probably end up in the same stream after the demux.
IIRC the modular SGDMA doesn't support channels either, so you may have to replace the channel adapter by a component of your own that assigns a channel number to each packet.
