15 years agoIs there any "side effect" when using GPIO in DE2-115 to receive 48MHz CLKIN ?
Hi, I went through the schematic of DE2-115, and i can be sure that, all of the GPIO pins connected to Bank 4 of FPGA chip does not support CLOCKIN function. The full compilation was not s...
15 years agoThe primary side effect as you mentioned is the inability to effectively use a pll off that clock. However you can still use it as a clock signal, it just may have some extra input delay due to the fact it doesn't have the dedicated routing resources to the global clock lines.
Pete
