13 years agoIs it possible to write a design over PCIe into Flash?
Hi everyone, I have the following problem: I'm working on a device with a JTAG interface which is only accessable while the device is outside its case. Once it is in its case the JTAG interfa...
13 years agoI don't know if the EPCS Serial Flash controller is still a good idea. The documentation is very poor and Altera says: "Altera does not publish the usage of the control and data registers." and "The core must be connected to a NIOS II processor.".
I can't use a NIOS II because I can't buy the license! I just want to write from my Debian-Box over PCIe to the Flash-Memory. Isn't there a simple way to use a license free core and test it with the "pci_debug"-Tool? http://www.ovro.caltech.edu/%7edwh/correlator/pdf/altera_pcie.zip Is there a way to include the Altera EPCS-Driver into the Debug-Tool?
