13 years agoIs it possible to write a design over PCIe into Flash?
Hi everyone, I have the following problem: I'm working on a device with a JTAG interface which is only accessable while the device is outside its case. Once it is in its case the JTAG interfa...
13 years agoYou mean I can connect the flash-device with the tri-state-circutry?
And for the bus cycle sequence I can read the datasheet of the flash-device? If this is so, than I also think this is easy. And what about the flash-file? Do I have to write own Software to write it to the flash or do I simply have to put it in the flash? Thank you Steffen
