13 years agoIs it possible to write a design over PCIe into Flash?
Hi everyone, I have the following problem: I'm working on a device with a JTAG interface which is only accessable while the device is outside its case. Once it is in its case the JTAG interfa...
13 years agoIf you work out the bus cycle sequence required to write to flash (not that difficult), there is no reason why the cycles can't be generated from a remote system over the PCIe interface.
