13 years ago
Is it possible to use Dyn Partial Reconfig using Nios II DevKit Stratix II Ed?
Hi people,
I have in hands a Nios II Development Kit Stratix II (EP2S30) Edition.
I need to use the feature called "Dynamic Partial Reconfiguration" (DPR) because I need to develop an application that is based on an heuristic approach.
This approach requires a different circuit to be tested on every attempt.
So, at each new attempt requires a new .vhd file to be synthesized.
The 'size' of the file that carries each new circuit is not a problem. It is small enough to fit in a piece of the EP2S30.
Based on this here is my question: Can I do my work using DPR through this Kit?
Notes: the circuits will be built using pure VHDL (not through C code/soft processor); Initially I don´t have engough resources to buy another development kit.
Jaraqui
    Thank you very much Dave!
    I agree with you. It will be important to have a notion of how much time each solution-circuit-candidate spends the total time, from .vhd to the downloaded bitstream.
    And, in this sense, Stratix II will help me.
    Best Regards
    Jaraqui
    --- Quote Start ---
    --- Quote End ---
    Yes and No :)
    The Stratix II generation does not support partial reconfiguration. You would need to use a Stratix V device for that.
    With the Stratix II device, you will have to reconfigure the whole device for each design. This should be sufficient for your needs (it will at least be useful as a proof-of-concept).
    Cheers,
    Dave
