18 years agoIs cyclone II reconfigurable?
Hi Folks, I'm pretty new to Altera FPGA systems. I intend to do a project related which deals with a low-cost reconfigurable architecture and I'm intend to use a Cyclone II EP2C20F484C7 device....
18 years ago@std_logic, Avatar
Thank you for your response. Now, this isn't exactly my project but its something similar, wrt implementation methodology. " a dynamic self-reconfigurable mobile robot navigation system -- A mobile robot navigation system must adapt to the highly dynamic environments and emergencies under the real-time constraints. Sometimes some sensors may not work well with new environments while others may need to swap in at runtime to continue the navigation. This is an an agent-based embedded system platform which can dynamically reconfigure the robot system on the fly by integrating FPGA hardware and high-performance microprocessors system. Several dynamic reconfiguration models are described to improve the system efficiency with low reconfiguration latency. The reconfiguration architecture specifically for vision system is also presented. This platform can be easily extended to other robot systems, such as server robots, space robots, and multi-robot systems " source: http://intl.ieeexplore.ieee.org/xpl/freeabs_all.jsp?tp=&arnumber=1511230&isnumber=32215 Will I be able to implement something like this on the cyclone II board?
