15 years agoIs chip fried? Can't access JTAG chain
I'm new to Cyclone IV design... I accidentally applied 3.3V to the core of a Cyclone IV today, so it's very possible that the chip is fried. When I try to configure it, I get the "Can't access JTAG c...
15 years ago --- Quote Start --- That was good info. The supply voltages are good. And the supply rail impedance is practically 0. So maybe the chip's alright --- Quote End --- This information is inconsistent. If an ohm-meter indicates 0-Ohms between the core voltage and ground, then its a short, and you would not see a voltage when you turn the supply on. (You be making the impedance measurement with the power off). The I/O impedance can sometimes be close to 0-ohms if you have a lot of bus terminations, but for this test, you just want to look at the core. --- Quote Start --- When I step through the JTAG state machine in the debugger, I don't see TCK or TDI change. TDO and TMS do change, but they only fluctuate between ~0.7V and 0.9V. (I'm expecting 2.5V) So I'm thinking the USB-Blaster that I bought on eBay is the problem. Cheap Chinese knockoff... --- Quote End --- That definitely sounds like an issue. The Terasic USB-Blasters are cheaper than the Altera ones, and I've never had a problem with them. Cheers, Dave
