8 years agoIP generated by Intel HLS Compiler is Missing Module IP in Platform Designer (Qsys)
Hi, Sorry for my poor English!!!:oops: -- Intel HLS Compiler (i++) can generate IP component for Platform Designer. I can make IP component by i++. I make my project in Quartus P...
8 years agoAre you able to see the IP you created using HLS?
From what I know we go to tools -> options and update the 'Quartus project IP search path' to where our IP is located. This then will update the path and show your IP in the 'Existing IP variants' section. From here it is easy to add your IP. Hope this helps. -Saumil
