18 years agoI/O Pin Assignments
I'm not completely sure how to do pin assignments. Let's say I want to assign Input to an onboard switch and output to the LEDs. I know that I am supposed to use the Pinout table for my FPGA (Stratix...
18 years agoIf you compile your design with Quartus first with no pin assignments then Quartus will place then pins wherever it likes.
You can then use the pin editor (Assignments Menu->Pins) to reassign the detected IO pins to the location that you require. Hope this helps. Could idea to read the tutorial as suggested if you get a chance!
