15 years ago
I/O asignment using Problem
Error: Can't place output or bidirectional pin VGA_G[2] in input pin location A14
Error: Can't place output or bidirectional pin VGA_G[1] in input pin location B14
...etc
I found that the problem only happend in using bidirection or outputon CLK pins.
Is that means Clock pins can only use on input pins?
By the way, I also want to know if I using CLK as input data,Bad?
will Other pins do same problem?
    HaHa, Thank you Guru!
    I found a document PCG-01003[1].pdf at atera's website.
    I got to change my design includes PCB layout.
    Apparently you tried to use a dedicated input pin as output. There are only a few pins, that aren't suitable as outputs. As the hardware manual, pinout files and Pin Planner tool clarify, clock inputs can be still uitilzed as logic inputs.
