17 years agoInterruption program
Hello, I am trying to do an interruption of a video signal. I am using the hsmc quad video card of Bitec associated to a cyclone III C25 Altera card. An interruption is supposed to be generated...
17 years agoHi Jérôme,
I come back to you as I managed to target my problem... I attached to the mail my sopc design. When I put everything to onchip mem in the system library properties, everything works. Then, if I put everything to ssram or ddr-sdram except program memory (to onchip mem), nios II compiles but the program does not work. Then, if I put everything to ddr sdram, I have the traditional : Verifying 00010020 ( 0%) Verifying 04000000 ( 2%) Verify failed between address 0x4000000 and 0x400369F Leaving target processor paused I don't understand how system library properties is related to quartus II. Why doesn't it work with ssram ? I did not even add it like the ddr-sdram, it was already in the original design... Thanks, Myriam
