18 years agoInternal LVDS for between-board communicatino
Hello, Suppose that I have two boards with Stratix II FPGAs. The boards sit close to each other, and lines from one FPGA reach the other, via a connector. The total length is circa 20 cm (8 inc...
18 years ago --- Quote Start --- Whoa let's not make this too complicated. If your grounds are seperated with no way of making them common, then yes your best bet is to run differential. If your grounds are not related to each other in some way, then you have absolutely no way of knowing what the potential between the two is. However remember we're only talking 40Mbps here. Run four traces (a differential clock and a differential data signal). Use AC coupling caps on the traces (preferably close to the receiver). And use a simple DC-biased termination scheme. If you provide the clock, there is absolutely no need to encode the data. Encoding schemes like 8b/10b are designed to provide a maximum number of transitions to allow for easier clock data recover at the receiver. Just provide the clock. I assume that your boards have been layed out with differential traces? Jake --- Quote End --- Yes, if I provide the clock I don't need to encode the data. No bad effects will happen if a AC-coupled line stays high for too long ? My boards are in the design phase, and we plan to use differential traces, yes.
