18 years agoInternal clock generation
Hello frnds, To put the problem very simple, I want to generate a clock of 10hz from 25 MHz. This 25 Mhz is being generated by PLL inside the FPGA and 10 Hz I want to generate ...
18 years agoYou can use binary counter template from Quartus HDL editor context menu. Set MAX_COUNT to 2500000. Don't use the q binary output but generate a ckl10hz std_logic that is active for one input clock cycle, e. g.
IF cnt = 0 THEN
clk10hz = '1';
ELSE
clk10hz = '0';
END IF;
