18 years agoInterfacing MaxII Micro to 5v TTL
Hello, I got myself a Max Micro kit, and I'm planning to interface this with a 5v TTL device. But I'm not sure if I\O pins are 5v tolerant. What can I do to interface a max micro to 5v TTL devices...
18 years agoThe Max II handbook is giving detailed answers to all questions raised here. There is particularly a paragraph titled multivolt i/o interface.
1. Max II clearly isn't 5 V tolerant. 2. TTL inputs can be driven from MAX II banks with VCCIO of 3.3V (3.3V LVCMOS I/O standard) without level translation. 5V CMOS logic needs level translation, cause minimum Vih can't guaranteed. 3. To drive MAX II from 5V-logic, you can use voltage dividers, series resistors with clamp diodes (for some MAX II inputs, internal pci clamp diodes can be activated) or level translation.
